Well I bought a length of 63mm exhaust pipes and decided to get it done. The box closest to the motor was easy as it was just cut box off and weld a straight pipe in its place. The large centre box was more awkward as the inlet and outlet dont line up, so it was a matter of doing the cuts at an angle so it would all line up. The rear box was then cut off and the tail piece was routed through the rear bumper to help keep it out of harms way when off roading.
Anyone thinking of doing the same I would like to point out that with the joints having little to no movement in them, so its best to tack it all together and make sure it lines up before you fully weld it up to be on the safe side .
[youtube:gj81v4zm]b8wH1EfwoSg[/youtube:gj81v4zm]
