Bounder said:
I wonder what part failed first?
I think that it was the drivers side, side gear to fail first & now that I've had time to consider it I believe that the damage was done on my trip to Wales while driving a very onerousness stepped climb! To be fair to Yotas engineering I've then gone on to use the truck @ Lincomb & in Shropshire, so not only giving her plenty of off road stick, but driving in excess of 1000 road miles as well!
Chris said:
Given how easy it is to swap it out, you might decide to give it a thorough cleaning, pick the bits out of the teeth, put it together and give it a go for the moment. Whilst you keep your peepers open for another. I have no doubt that it'll run with the carrier swapped. Just used on the road it'll probably run forever!
Patch up and cross fingers
Jon Wildsmith said:
The carrier damage looks cosmetic and you'll probably get away with the R&P damage. -------------------------, give the bearings and housing a good clean, put it back together ---------------, swap the carrier side & pinion gears from another carrier and refit. After you clean each bearing give it a good dose of oil and test it back in its race to feel for notchiness - any that are still notchy may be a problem but having to buy bearings may make it a write off when you do the sums.
This is where I'am at this moment in time really, I've had a good chat with Chris on the phone (hope you've found your Blackberry m8) & he has sent me all of the left over parts that he had from out of
Lil-Blues diff when he fitted the locker (carrier c/w side & sun gears, side bearings & cups etc). Once I get the last tooth fragment out from between the two Pinion bearings a quick but thoughtful rebuild using
Lil-Blues old bits & a small
'er or two to get
Fiery back on the road, hopefully buying me some time to find the right replacement complete front axle housing & diff.
Lil-Blues diff carrier & Fierys are what would be termed two pin, but I've read that these are notorious for failiure while searching for info on the web and that as such Yota upgraded them to 4 pin. My first thoughts were to try to obtain one such item & then work towards an 4.3 ratio front diff rebuild using a 4 pin carrier, but as hard as I've looked I can't find any evidence of this upgrade even using ToyoDIY.
It's not that I haven't been offered many diffs either (mostly the wrong ratio thus far) but I just want longer to become more familiar with all of the options, so fingers crossed that this union of
Lil-Blue &
Fiery lets call her
Lil-Purply for now
Is a happy one
Just for interest here is a list of what I've been offered in the way of axles to date
£160 inclusive of VAT & post - USED - (incorrect ratio for me 'R56' so no good)
£250 inclusive of VAT & post - USED - (incorrect ratio for me 'R16' so no good)
£280 inclusive of VAT & post - USED - (incorrect ratio for me, man said it was an 'R57'
so no good)
£358 inclusive of VAT & post - USED - 2 month warranty (correct ratio for me 'R17' but not confirmed)
£480 inclusive of VAT & post - USED - 3 month warranty (correct ratio for me 'R17' but not confirmed)
£576 inclusive of VAT & post - RECON xchange - 6 month warranty (correct ratio for me 'R17' but not confirmed)
£600 inclusive of VAT & post - RECON xchange - 12 month warranty (correct ratio for me 'R17' and confirmed) - I'm very tempted by this one
£909 inclusive of VAT & post - USED - 2 month warranty (ratio not confirmed)
