As title really!
Noticed it first when turning full lock right at slow speed into petrol station in prep for journey home from Telford this weekend. It was a kind of a clonk-knock with an accompanying jolt that both my passenger and I felt and simultaneously said 'That didn't feel very good!' Following the normal lay underneath & cursory tyre kicking we aired up, fueled up and made for home without any further trouble until 200+ miles later as coming from off of the A12 into my home town, again at slow speed turning slightly right (around a roundabout) clonk-knock, jolt!
Anyways cut a long story short I've emptied her, cleaned here all up and had a good lay under her looking for damage or problems, given her a clean bill of health & used her for the school run today, both ways.
So this morning goes like this
clonk-knock, jolt................................clonk-knock, jolt................................clonk-knock, jolt................................!
And then this afternoon like this
clonk-knock, jolt...............clonk-knock, jolt...............clonk-knock, jolt..............clonk-knock, jolt...............!
Just been out for a run around in her this evening and I've now got her going
clonk-knock, jolt..clonk-knock, jolt..clonk-knock, jolt..clonk-knock, jolt..clonk-knock, jolt..clonk-knock, jolt..clonk-knock, jolt..!
Whatever this is is not getting better with use
So get out the trolley jack me thinking wheel bearing, maybe CV joint But apart from about 2/3mm play in the steering (maybe a little bit more ) I can't detect any fault with the wheel bearing & or the CV's
When you can get it going clonk-knock, jolt there is also alot of tourque steer & she feels all loose up front The fault is more prevelent at slow speed right hand down on the steering but is also there when left hand down but with more lock than when right hand down, but here's the bugger in 1st gear putting the power down with the sterring straight ahead you can get her the play her new tune aswell
I'm going to have to take her into my mechanic on Monday for a look see, but till then what do we all reckon
I'm starting to think front diff
