Kellys Hero
- Oct 21, 2017
Hi
Been having some braking problems so replaced the pads etc. (no pipes disconnected) however I needed to pump the pedal about 50 times to get pedal back, brakes work fine on the initial use, but fade dramatically on the 2nd 3rd and continual use.
My initial thoughts are the pump, as the steering also seems slightly heavier !
Am I right in saying this pump serves both brake servo and steering?
I have tried the test of engine off, foot hard on the brake pedal and starting the engine, brake pedal moves to floor as vacuum is made.
Any suggestions please?
If it is a pump! are the refurbishment/rebuild kits available ?
