- Jul 24, 2015
Next job is to replace the rubber brake hoses with braided ones. Just trying to understand the procedure.
Presumably I need to drain the brake fluid until the system is empty at bleed nipples on each wheel before I can undo the hoses? Is it a case of putting some tubing onto each bleed nipple and letting gravity do the rest? or is there more to it?
Is there anything I need to know about undoing the old brake hose's, or installing the new ones? Do I need some kind of thread sealant or anything.
Then once I have changed out the hoses I need to re-fill the system. What is the best way to do that? I'd like to do it without specialist equipment if possible, so if I ever have a problem while on an expedition we can use the same procedure. I believe you have 2 people, 1 pushing the brake peddle while the bleed nipple is open, and 1 closing the bleed nipple while the brake peddle is lifted. Keep going until the new fluid comes out of the bleed nipple then stop.
Any thoughts anyone?
