Brakes questions, (runout, possible calliper rebuild)
Thanks for the link Paul, will look into prices of pipes next week.
No slide pins on the front and the rear ones are working perfectly. Not replacing the rear discs as the cost of this latest work is starting to spiral out of control. Need some cash to send on fuel on the Morocco trip.
Hah, was just about to order the very same thing Rob! Bet they don't keep many in stock. I have slide pins on my front calipers though, for sure.
They make everything to order Chris, at least they do for landcruisers. If you order on Tuesday you will have them by the end of next week as they cyro treat them over the weekend.
Are you talking about the 2 pins that stop the pads falling out? It so what is to check on them?
Sent from my GT-I9100 using Tapatalk 2
Yes, the two pins that the pads slide on are the slide pins. I didn't say to check them. I just said that there were pins on mine, Rob. Checking that you have them might be a good idea ha ha. I stick new ones in generally. Milner sell them. They can have a hard life.
Their web site wasn't working this morning. Going to try again.
