Paul_Driver
- Mar 5, 2010
It's been a while, hello everyone.
My rear half-shaft broke over the weekend and I thought I'd post a photo as it seems fairly exceptional to me. My thanks to Julian Voelcker of http://www.overland-cruisers.co.uk for talking me through the problem so far.
The break is so clean you could think it been cut with a fine tooth sawn. I should say also that when I got the truck jacked up, there was a slight amount of play in the wheel bearing, may be 1-2mm worth.
Of interest is that in there are grooves around shaft suggesting wear and heat, and Julian suggests that this might be down to the wheel bearing
Presumably the next challenge will be getting the rest of the half-shaft out. I guess I have to take the diff cover off try to push it out from there.
Any thoughts on a good procedure for this?
