Paul_Driver
- Mar 5, 2010
Well I've got a replacement half shaft from Stef, but it is slightly different from the broken one and doesn't seem to fit.
They are the same length and I'm pretty sure it's from an 80, but there appear to be two differences.
1. The grooved area that fits into the diff is shorter; instead of being about 4", it is nearer 2"
2. The bolt holes look like they take cone washers, but mine are flat.
Also when I insert the shaft into the axle it won't engage the with diff. It should click in easily shouldn't it? Or is there a knack to it?
