wobbly
Okay, so there may not actually be a real live budgie living in the nearside hub, but there is a definite chirping noise coming from the vicinity.
I dont think its the CV joint - mainly cos the offside one needs changing and doesnt sound like it.
If the bearing was on its way out, would it make a squeaking noise?
If I lift that corner, then spin the wheel, it may isolate the noise, as it could be suspension related. It continued the noise independent of braking, and isnt brake squeal.
Are the bearings hard to get out of the hub? Ideally I would like to do it with the hub in situ so I dont have to re-do the brake pipes, but I have read that a press may be needed for bearings, which means hub off really.
Seems the truck needs a bit of fettling at the moment, what with the o's cv joint, new pads all round and new discs on the rear.
Pete
Pete
