Chris Green90
Thanks Chris. That was the info I was looking for. Never even thought about this and never really had a.need.for it but just figured that if it was as.easy as the 80 to do then why the hell not.
Brett said:A full time 4 wheel drive with open diffs is basically a one wheel drive when you lose traction!
Dave Docwra said:Hi Brett, what happens if you disengage the rear diff lock & leave the front engaged on corners
I think you know what would happen DaveDave Docwra said:Hi Brett, what happens if you disengage the rear diff lock & leave the front engaged on corners
This is true, then you would have an "amount" of drive split between front & rear.Towpack said:Brett said:A full time 4 wheel drive with open diffs is basically a one wheel drive when you lose traction!
..............unless you have a VC in the centre diff.
