Chassis cracked
nlbyrne
I bought this 80 five months ago and has been parked up since.
Steam washed the under side at the weekend and found this :shock: :shock:
Crack at steering box.
This is where the panard arm mount is fixed to the chassie rail under the steering box.
It seems it had a low hard impact and had the steering shock mount welded back on also.
What do you's think I should do, it stands me only €800 so could sell it for parts very easly.
I have seen this problem on other sites where its been lifted and running big rubber,
they just weld a plate around it and drive it on.
Any ideas :idea: :?:
I don't see why you shouldn't just effect a repair as you describe above... Grind out the crack, weld it up & then weld a plate over it all???
It would be a shame to break an otherwise (presumably...) solid truck.
Are they some sort of bucket seat I can see in there???
[quote="Are they some sort of bucket seat I can see in there???[/quote]
Ye they are some kind of bucket seat they were in it when I got it,
not sure what they are out of.
The truck is originally from the UK, imported 6-8 years ago.
Paul_Humphreys said:
It is a common place for them to crack.
Paul
Ye have heard of it being a problem.
Two of us missed the crack at the panard only seen it when I got it over the pit.
