Anthony
On my truck which has ABS, as originally supplied:
* the centre diff lock (CDL) was engaged when you selected low ratio, there was no manual switch.
* the rear diff lock could only be engaged if the centre was engaged
* the front diff lock could also only be engaged if the centre was engaged & rear selected (but not necessarily engaged).
Therefore diff locks were only available in low range and, worse still, using low range enforced the selection of the CDL.
This was standard for ABS fitted vehicles, and engaging the CDL inhibits the ABS system. Those without ABS had a manual CDL switch, and I think this could be engaged in either high or low ratios, although the front & rear diff-locks followed the logic above.
I, like many people, have disconnected the "engage CDL when in low range" switch on the transfer case and have replaced it with a manual CDL switch on the dash - as for non-ABS equipped vehicles. On a manual gearbox this is sufficient, but on an auto you may have to fiddle with the "pin 7 mod" to get correct shift vs speed behaviour.
So I can now engage the difflocks in high, low or neutral. Engaging the CDL still inhibits the ABS, and the front and rear diff locks can still only be engaged when the centre has locked up. Also if I have front & rear locked up and I switch off the CDL then the front and rear locksalso disengage, regardless of their switch setting.
As far as I know there is no way of "locking the locks on in high range" in a standard (ABS equipped) vehicle. (And I, for one, would hate to try it at any speed!)
Christopher Bell
Devon, UK
1996 1HD-FT
> There seems to be some differences concerning how the axle locks will operate.
> Some say that in order to operate them the low ratio need to be engaged.
> Others say the axle locks can be engaged regardless of whether the low ratio is engaged or not.
> Some say that to operate the axle locks in high range the CDL must be engaged firsts.
Some say that to engage the axle locks in high range they must be engaged in low first and then with out switching them off high can be engaged and they will remain o
I would like a poll to see what the consensus is as across the ELCO forum as across the pond there is a variety of strong opinions of how they are engaged. I think that I have covered the list of options, what do you thin
> Anthony Graham
Christopher Bell
Devon, UK
1996 1HD-FT
> Anthony Graham
