- Mar 1, 2010
Having resealed the clutch cylinders and refitted them I had trouble with the bleeding. Even with 2 people it took 2 litres of fluid, a heart attack, three nervous breakdowns and a migraine.
Had to stand on my head on the drivers floor to remove the internal nut on the m/c. Never seen that design before.
First of all no fluid would come out even with my assistant holding the clutch pedal on the floor so lightly compressed air in their had a chance to come out whilst I held the bleed nipple open. In the end fluid came out with air and then solid with some air. Then aerated fluid. WTF the reservoir had run dry. Even though it had 10mm of fluid in the bottom the vacuum when lifting the clutch pedal up with nipple closed had sink holed the surface. So I got my helper to lift the pedal up slowly to avoid this happening again but it did because 4 pumps of the pedal is all it takes to empty the reservoir completely. So 3 pumps then refill etc etc. Got there in the end I think.
