A brilliant description from a very frustrated guy who claims to be a VW race team mechanic trying to get through to someone who is convinced catch cans are for cleaning oil -
I don't think you understand:
- What I wrote above.
- The purpose of the PCV system.
- The function of the catch can.
I tried explaining it as clearly as possible in the two posts I made, but I'll give it another go:
The PCV system is called the "positive crankcase ventilation system" because it is designed to ventilate pressure from the crankcase.
During the operation of an internal combustion engine, there is blow-by, and the crankcase can become pressurized. If the crankcase is not ventilated, this pressure will cause seals to leak.
A long, long time ago, the crankcase could just be ventilated via a
breather filter.
However, due to emissions regulations, manufacturers aren't allowed to emit anything directly to the atmosphere. Also, having a slight vacuum in the crankcase is actually a good thing. As a result, modern PCV systems are routed back to the intake tract. Some only ventilate through the air intake, while others use a check valve to also provide crankcase ventilation through the intake manifold (after the TB) under vacuum.
Now, since there is a lot of oil present in the crankcase, the crankcase gasses usually have some oil vapor present. This oil is now being introduced into the intake tract. That is why you can see oil in the intake plumbing, intercoolers, and intake manifold.
What a catch can does is act as a separator. It separates the oil particles from the crankcase gasses, allowing the crankcase to be ventilated while minimizing the amount of oil that makes it to the intake tract.
The oil that is separated is perfectly useable oil (it just came from the crankcase, where the rest of your oil was) and can be reused. Draining back to the oil pan adds a bit of complexity to the catch can, and requires more parts, but reduced oil consumption, and eliminates the need to manually drain the catch can.
The purpose of the catch can is to keep oil out of the intake tract, not to keep oil out of the crankcase.
Opting to drain the separated oil back to the oil pan does not "defeat the purpose of having a can" since the purpose of the can is not to remove perfectly good oil from the crankcase.
