- Feb 2, 2013
I would pull the new stat to check its working , coolant is not circulating so if not the stat at fault there's blockage somewhere so you might get lucky removing and flushing the radiator , and of course the system as well .
There's a tiny drain plug rarely found or used on the right hand side of the block for coolant , I undid it when i drained mine and was unimpressed but perhaps its there in sympathy to some sort of catch pit ?
Oh hang on that was on the 1kz-te , same block ? worth a look anyway .
