Yesterday I noticed that my passenger side CV boot was leaking some grease. Similar to Crispin's. Sorry can't post link but if you do a search on "leaking CV boot" you should see a picture that Crispin posted a while back. Although mine is not leaking as much. It's loose and I can turn it by hand. Soooo ... can I just purchase a stainless steel hose-clamp from store or should I stick with Toyo standard stock? On another forum someone just put some electrical tape around the boot a few times and re-used the existing clamp - not sure how good that will work...
Also, I'm pretty sure it hasn't leaked too much .... should I try and replace / add some grease? If so how can I go about that (without taking wheel off and dismantling everything...?) I thought maybe it's possible to try and somehow squeeze some grease back in there with a small grease gun or something else (suggestions welcome)..?
LC4 54 plate with 81K
Thanks Again for any input!
Riaan
Riaan
