Darrins sahara project (was first post/first toyo)
Hey Roman
Ok thats a list.
There are things in there a few times did you try to fix them when they
appeared or did they keep appearing.
I havn't got dates me being me of course but
Big end bearing went, result breakdown,
Engine rebulid,
New injectors etc,
New radiator needed,
Fuel pump went, result breakdown,
Second head gasket went,
Timing belt tenioner failed,
Timing belt ate through plastic timing belt cover,
CV joint went, result breakdown,
Oil leak at both front hubs,
New seals put in front hubs,
Second CV joint needed replacing,
Two drop links fail,.
Radius arm ball bearing I thing its called replaced,
Trailing arm brackets failed,
Steering box leaks,
Seized rear caliper,
Seized handbrake,
Brake disks worped,
Engine/Gearbox vibrating when in low revs,
Water leaks in front footwells,
Hoses for radiator replaced needed,
Two leaking shocks,
Poor headlights,
Leaking rear windows,
Electric window drivers side new regulator and motor,
Electric windows rear new switches,
Electric windows failing to this day,
Starting motor rebult twice,
Two new batteries needed,
Blown headlight relay twice,
Steering play cause not known,
Im sure there is more
john 92HDJ 80 1HDT
----- Original Message -----
To: <[Email address removed]>
Sent: Wednesday, May 31, 2006 4:00 PM
Subject: Re: [ELCO] Darrins sahara project (was: first post/first toyo)
John, is that on a Landy or a Toyo?
Cheers, Darrin
(who's HJ60 needs rear and front crack oil seals replaced he learned
today)
On 31 May 2006, at 16:48, John Byrne wrote:
Er, that should be crank seals - I shouldn't give away all of my
habits in the first week...
Hi Darrin
Thats on the cruiser that I have now.
cheers
john 92 HDJ 80 1HDT
On 5/31/06, jeff watts <[Email address removed]> wrote:
I haven't heard from the guy who bought it in 2003. Could be because
he is absolutely happy with this "best 4x4 by far" or maybe by now he
can't afford to make too many phone calls ...
Rgds,
Roman (London, UK)
'92 HDJ80
