Diesel Fueling?
Hi all,
On Sunday I'm off to Iceland for three weeks, which should be fun. I'm
just doing a bit of last minute tweaking of things and would like to
turn the fueling down a bit as the fuel consumption is high, =B113 mpg,
and it's smoking a lot which I suspect is over-fueling.
I'm a lot more familiar with petrol engines than diesel, and so have a question:
If I turn down the fueling can I turn it down too far and cause
overheating, burnt valves etc the way a petrol engine does if the
mixture is too lean?
Or does the engine just not get enough fuel so there is less power?
Thanks,
Andy Haxby
Macclesfield UK and Den Haag NL
HDJ81 with everything including the kitchen sink.
Fix the turbo to put in more air, where the fuel is unburnt at the moment.
The extra power will also =3D better consumption.
Darren McRae
Drysdale, Victoria, Australia.
95 FZJ-80 supercharged on 37"s SLEE front and rear bar/carrier+++
~-----Original Message-----
~From: [Email address removed] [mailto:[Email address removed]]
~On Behalf Of Andy Haxby
~Sent: Thursday, 30 July 2009 8:35 PM
~To: [Email address removed]
~Subject: [ELCO] Diesel Fueling?
~Hi all,
~On Sunday I'm off to Iceland for three weeks, which should be fun. I'm
~just doing a bit of last minute tweaking of things and would like to
~turn the fueling down a bit as the fuel consumption is high, =B113 mpg,
~and it's smoking a lot which I suspect is over-fueling.
~I'm a lot more familiar with petrol engines than diesel, and so have a
~question:
~If I turn down the fueling can I turn it down too far and cause
~overheating, burnt valves etc the way a petrol engine does if the
~mixture is too lean?
~Or does the engine just not get enough fuel so there is less power?
~Thanks,
~Andy Haxby
~Macclesfield UK and Den Haag NL
~HDJ81 with everything including the kitchen sink.
~European Land Cruiser Owners Mailing List
~Further Info: http://www.landcruisers.info/
Hi Darren,
I've got an intercooler, and when it was installed the turbo boost was
turned up until the light almost comes on when you drive hard. The
boost is controlled by putting a T-piece in the pressure line that
controls the waste gate. A small bleed valve on one arm of the T then
allows adjustment of turbo boost.
You've just made me think of something worth checking - maybe the
bleed valve is blocked or needs adjusting, I'll go check that first
before I mess with the fueling. Thanks for your swift reply!
Cheers,
2009/7/30 Darren McRae <[Email address removed]>:
No problem.
Next thing would be put the light on the lower boost side of the adjuster,
So it doesn=92t come on, and run some more boost 8-)))
Darren.
~Sent: Thursday, 30 July 2009 8:59 PM
~Subject: Re: [ELCO] Diesel Fueling?
~Hi Darren,
~I've got an intercooler, and when it was installed the turbo boost was
~turned up until the light almost comes on when you drive hard. The
~boost is controlled by putting a T-piece in the pressure line that
~controls the waste gate. A small bleed valve on one arm of the T then
~allows adjustment of turbo boost.
~You've just made me think of something worth checking - maybe the
~bleed valve is blocked or needs adjusting, I'll go check that first
~before I mess with the fueling. Thanks for your swift reply!
~Cheers,
~2009/7/30 Darren McRae <[Email address removed]>:
~> Fix the turbo to put in more air, where the fuel is unburnt at the
~moment.
~> The extra power will also =3D better consumption.
~> Darren McRae
~> Drysdale, =A0Victoria, Australia.
~> 95 FZJ-80 supercharged on 37"s SLEE front and rear bar/carrier+++
~> ~-----Original Message-----
~> ~From: [Email address removed] [mailto:ELCO-
~[Email address removed]]
~> ~On Behalf Of Andy Haxby
~> ~Sent: Thursday, 30 July 2009 8:35 PM
~> ~To: [Email address removed]
~> ~Subject: [ELCO] Diesel Fueling?
~> ~Hi all,
~> ~On Sunday I'm off to Iceland for three weeks, which should be fun.
~I'm
~> ~just doing a bit of last minute tweaking of things and would like to
~> ~turn the fueling down a bit as the fuel consumption is high, =B113 mpg,
~> ~and it's smoking a lot which I suspect is over-fueling.
~> ~I'm a lot more familiar with petrol engines than diesel, and so have
~a
~> ~question:
~> ~If I turn down the fueling can I turn it down too far and cause
~> ~overheating, burnt valves etc the way a petrol engine does if the
~> ~mixture is too lean?
~> ~Or does the engine just not get enough fuel so there is less power?
~> ~Thanks,
~> ~Andy Haxby
~> ~Macclesfield UK and Den Haag NL
~> ~HDJ81 with everything including the kitchen sink.
~> ~European Land Cruiser Owners Mailing List
~> ~Further Info: http://www.landcruisers.info/
~> European Land Cruiser Owners Mailing List
~> Further Info: http://www.landcruisers.info/
As Darren said no problem with going lean on diesel, oposite to
petrol, infact the additional air will also keep your exhaust gas
temps down.
Malcolm Bagley
(m) 07941 783158
On 30 Jul 2009, at 11:34, Andy Haxby <[Email address removed]> wrote:
mpg,
They always go best,
Just before they go BANG!!! 8-)
Darren McRae
~Sent: Friday, 31 July 2009 12:11 AM
~Well I turned the boost up and went for a spin. It smokes less and goes
~better!
~Thanks guys!
That's why I'm reluctant to relocate the little red light :-)
The best I ever had a diesel go was when I quit smoking (60 a day to
nothing overnight). I got a bit confused, forgot what car I was in,
and filled an Opal Vectra diesel up with petrol (from empty, a whole
tank). It ran normally for about a mile, then suddenly went REALLY
quick but only for a few yards. Long enough to scare the sh*t out of
me though, I nearly drove into the back of the car in front.
Wish they'd always go like that....
Hi Andy,
I once put a whole tank of unleaded in my cruiser, it drove OK for about half a
mile then sputtered and cut out and eventually came to a halt and wouldn't start
again, cost me 200 squids to get recovered and the tank drained.
TTFN
Chas
----- Original Message -----
To: <[Email address removed]>
Sent: Thursday, July 30, 2009 3:26 PM
Yes, and expensive!
Sent: Thursday, July 30, 2009 3:55 PM
Chas
200 squids?! Hey! Roast squid - mmmm, nice!
Renate
Behalf Of Chas
Sent: 30 July 2009 15:36
Hi Andy,
half a mile then sputtered and cut out and eventually came to a halt and
wouldn't start again, cost me 200 squids to get recovered and the tank
drained.
TTFN
Chas
nothing
Opal
for
Long
the
Yeah, and on top of that was the cost of a tank full of fourstar!
TTFN
Chas
Sent: Thursday, July 30, 2009 9:34 PM
Subject: RE: [ELCO] Diesel Fueling?
Could be worse. My wife did it twice to her Vauxhall Zafira. First time it came back to life OK, 2nd time it coughed and spluttered a bit but eventually revived after about 100 miles of rough running ...
... but then when they serviced it a few months later and replaced the fuel filter a bit of air got into the injection pump, and that was that.
Cost of new pump was greater than value of car, so we had to get a "new" car. Cost rather more that =A3200!
You can get an insert for about =A325 to go into the fuel filler that won't let you fill with a petrol nozzle.
Christopher Bell
| TTFN
| Chas
Hi Christopher,
Actually I have done it twice as well, in France on the way back to the UK from
Morocco I topped up the tank from about two thirds full. The Cruiser kept
running, but erratically, sometimes stalling completely, I found by pumping the
primer I was able to get it running again, it would run for a couple of miles
before cutting out again although sometimes it would only run for a few yards, I
just kept topping up with diesel as soon as the fuel gauge dropped and it got
back to normal after a 200 miles or so.
TTFN
Chas
Sent: Friday, July 31, 2009 9:51 AM
Cost rather more that ?200!
You can get an insert for about ?25 to go into the fuel filler that won't let
Christopher Bell
| TTFN
| Chas
Cruiser =3D Japanese engineering
Oldish injection pump with looser tolerances
Designed for 3rd world conditions
Can be primed with a simple push
Zafira =3D German engineering
Y2K Inj Pump with tolerances & finishes for low sulphur diesel
Designed for European conditions
Has to self-prime
The "new" car has a high-pressure common-rail pump, and goes like the
clappers, I wish the TLC had that sort of oomph. But apparently if you
put petrol into one of those it is curtains!
Given how common the problem is you'd think there would be different
shaped nozzles or something, wouldn't you?
Having had diesels for so many years I really have to concentrate when
filling up the little (petrol) Fiat Panda I got for my daughters. (Which
is currently on its 3rd front bumper in 18 months, I'm getting quite
good at fitting them. Daughters #1 and #2 are currently on full
licences, #3 has her test coming up in September...)
CB
| Hi Christopher,
the UK
| from
| kept
| pumping the
of
| miles
few
| yards, I
it
| got
| TTFN
| Chas
Chas
Not good dear heart, not good at all. I nearly put diesel in a petrol
engine once but remembered just in time; my understanding its not as bad as
the other way around, but I aint going to wait to find out...
I'm on biodiesel now - there is just one supplier here in Bristol. Its not
all biodiesel, obviously, there doesn't appear to be that much a different
in driving, but that is only because it's a mixture of dino juice and plant
juice.
I'm in the process of getting miseln some contracted work overseas in Egypt
Renate
Behalf Of Chas
Sent: 30 July 2009 22:18
TTFN
Chas
On
Hi Renate,
I think putting diesel in a petrol is worse, glad to hear you are getting some
work, don't forget , Nil illigitmate carborundum!
TTFN
Chas
Sent: Friday, July 31, 2009 1:11 PM
Chas
Don't you blind me with Latin dear heart...so wosat mean then? In'shallah to
the north African projects and nil consumption of carbon? Hahaha!
Renate
Behalf Of Chas
Sent: 31 July 2009 14:13
Hi Renate,
some work, don't forget , Nil illigitmate carborundum!
TTFN
Chas
as
Egypt
Nah! it's Don't let the Bastards grind you down.
TTFN
Chas
Sent: Friday, July 31, 2009 3:19 PM
