Chris Green90
Hi guys.
Back again from the 90 side and have a question about diff locks. Some of you may know that I am doing a solid axle conversion and swapping out the rear axle on my swb 90 for 80 series ones. I have been having a thinky about the lockers. On the 90 the rear is control'd by the ecu which will not allow it to be activated in anything other than low box. Now with all the changes I am making the sensors and such that tell it that it is in low box will not be there. (plus it never had a front locker) so I think I will just be wiring up some switches.
I would have thought momentary switches best (like electric window ones.) just hold it down for a few secs then cut the current.
The main thing I could do with knowing is what sort of current the acctuators are likely to pull as I will need to go and get 6 relays to sort out the DC voltage swap (Won't I Jon????) 2 for front, 2 for back and 2 for centre.
Thanks in advance guys.
