Engine block drain cocks
Bat21
morocco
To save me spending hours trying to locate the little blighters, can anyone tell me where the two drain cocks are for the engine block for the 80 TD?
Posted this the other week on a thread about 80 drain cocks oddly enough Paul. It was one of Rob's. I found the one on the block between the IP and the oil filter. Have a quick look back as I can't be bothered to type it all out again, mate. As far as there being two I have never heard tell of the other. The is one on the rad, but I just pull the pipe off and toy can pull the stat as well, but not sure why there'd be two on the engine itself. I shall have a quick look and if I can I shall paste it in here before the edit runs out. Hang on a mo.
Yep. Here you go. Last post on the thread.
viewtopic.php?f=15&t=7942&hilit=drain+cock&start=10
Thanks Chris, I did have a mooch at the manual after posting the question but, your description of the location and what to look for is much clearer :thumbup:
