- Feb 2, 2013
Fridayman your truck is set up exactly as mine was (while searching for info before fitting the cooler i did see some minor variations) . Just whip the inlet pipe off and you will a far better idea of which way to go . There's 3 or 4 components actually bolted to the pipe which will need to be reseated somewhere after the cooler is installed . To be honest all my electrical connection are just tied to a pipe on the bulkhead in a temporary fashion and had been forgot about until now , makes no difference though they are all connected and haven't caused any problems that i know of . There is nothing fancy about the adapter manifold i had made its just a flange plate with a bit of tube welded to it , any custom exhaust place can make this with their eyes closed , and because it's steel (stainless in my case) you case weld a bit of metal to it for the throttle bracket to bolt to .
