- Feb 2, 2013
Remove this and all ancillaries
Template for your custom part
Custom made part (sorry couldn't remove it i had the cooler off before i realized i had no instant gasket left)
Silicone hose on outlet
General overview of both openings
Silicone hose to couple custom part with cooler
Throttle adjust cable bracket
And only 1 bolt to hold the cooler secure
The actual fins only the toyota cooler measure 310mm by 230mm and its about 60mm thick the inlet/outlet are outside the measure and slightly offset but the overall outside width is about 470mm .
470mm
470mm
