I use 500ml per tankful of diesel (94ltr)What's the ratio? and how often do you have to use it also are they all the same or is there any brands to keep away from?
Thanks
Thanks
mmmm interesting stuff.Ram, recommended ratio is 1:200 thats 0.5%.
Plenty info here:
http://www.freel2.com/forum/topic878.html
...and here:
http://www.4wdaction.com.au/forum/viewtopic.php?f=54&t=76845
Stick to non synthetic, JASO FB and above.
Imtiaz
Be very very careful running on kerosene (domestic heating oil). AFAIK its as illegal as running on red diesel.
Granted it doesn't have the dye in it like red diesel, but if VOSA pull you and put the exhaust probe in the exhaust they will find all the chemical tracers in the kerosene.
At that point you loose your car.
If I had a cheap few hundred pound car (old diesel astra for example) then I would take the risk and run on red.
But in a vehicle like a cruiser which has cost a good few thousand pounds, IMHO its not worth it.![]()
