Fuel Reserve Light
Meri_gadi
Hi all...
The reserve light on the Fuel gauge is not working. Even on ignition before the car is started the light doesn't come on in the cluster.
Went to Mr T and they inform me that i need a new Speedo cluster around 950+VAT.
Now i need to know are they repairable? Can i change the bulb in it or is LED that cant be repaired or can i get a used part.
She has 150k and seen alot of reserve lights lol.
Can't see why it could not be repaired if you wanted it to be. Mr Richard just replace...
Even if it's an led then it could be changed by someone competent with various soldering iron.
You'd have to take it out to see where the problem might be.
Maybe an auto sparky?
Sent from my GT-I9300 using Tapatalk 2
