Fuse box with built in relay
Paul
As i want to fit another fuse box under the bonnet i would like to get one which is similar to a factory fit to reduce wiring etc, by which i mean having a built in relay that i can connect to the ign to enable power to the box and internally connected to one side of all the fuses so i only have to connect to the item, or switch for the item i want to fit, to one side of the fuse.
I could make something but might be easier to buy one.
Wow the battery distribution box seems perfect :thumbup:
You got a ref number for that Paul?
Its the second link by sae70 above.
Ah! cheers Paul, got it now, but would there be enough room on top of the battery for this to fit without touching the bonnet? it's quite close on my 80.
Thats the test i suppose, i've always found that company helpful so i will do some checking
