When the fan is working correctly you can hear it roar when it's hot enough to lock up. it will also do this for the first minute or so after a cold start until centrifugal force distributes the oil. When at 'normal' temp,the fan is just coasting and can be stopped spinning quite easily. When you think the engine is hot enough to lock up the fan just stop, switch off the engine and see if it is actually locked.
