HELP!!! PLEASE!!!!! Colorado 97 3ltr
Juliehaha
This car just will not go.
I was driving along and the car lost power then all the lights came on.
It has now been in a garage for 2 weeks and no one knows why it won't go.
It turns over, if you spray easy start in it, it fires.
ECU has been changed thanks to the kind man at OVERLAND in Burgess Hill, lending us one. Not the problem
However the LED immo light is not working.
Could it be an immobiliser problem. There have been numerus men under the bonnet scratching their heads.
The last result will be the Diesel pump, DENSO.
This is a 1kz-te enigine.
We have had a diagnostic done on it, but this was a waste of time.
Please any help would be really appreciated.
Also I only have keys for this car, no RCU. Could this affect it?
Funny, feel like we have answered this one last week somewhere else.
Well I would check the fuel cut off valve relay.
Hi. Not that up on the colorado but if you need a pump I should have one. I don't know what electrics they have. But with the 80 if you put fuel to it and a live to the pump as cris mentioned you can get s engine to run just sat on the floor. If it is alarm then just cut it out. Had to do that on mine. Doesn't take long. Pm me or get my num off seller part of forum if you need to. Karl
Thanks Chris, that has been checked and its ok.
Karl, the pump on this is electronic, it's a DENSO. Would you have one of these?
Thank you. :think:
I think so too. Check the Spill Control Valve relay too.
Thank you KZJ90.
The mechanic had been looking for this spill valve. He will look tomorrow.
If it's not that it is off to a TOYOTA workshop. :pray:
If you decide it's the pump you want I should have one by next weekend thanks karl
Thanks Karl, will be in touch if that is what is needed.
The spill control has been checked, thats working.
Off to Toyota on Monday for all electrics to be checked now.
