- Jul 24, 2015
OK so on my 105 I have the Toyota installed sub tank with a switch that changes between tanks, and which should change the fuel gauge to show the level of the tank you are running from. However this has never worked (since I got it anyway). I took the switch out and tested it and sure enough there doesn't seem to be any current from (I presume) the sub-tank sender unit.
So after removing ALL of the built in expedition set-up and loads of
'ing around I have got to, and removed the cover to access the sender unit. I have alto managed to tease out the old rust cover screws which was a bit of a win.
HOWEVER here I am stuck. I can't remove the sender unit from the tank because there isn't enough slack in the cable. I don't want to just pull it. Photo of the sender unit below
Should that blue cover come off the top of the sender? If so how (I tried wiggling it but there is no play). Or is there a way of getting more slack out of the cable?
Any thoughts anyone????
N
N
