- Nov 19, 2010
This might require a bit of help from overseas where the V6 Prado/Colorado is a bit more common.
The Collie starts up and runs fine but when it's warm it has a hesitation for a second before it sets off from a tickover, as you would set off from a junction or entering a roundabout from a standstill. After the slight hesitation it sets off with plenty of power and above tickover it runs fine. It feels like the enrichment it needs isn't there for half a second.
It will do this if it's stood with the bonnet open and you manually snap the throttle open.
The plugs have done less than 20K.
Although its ODB1 it has been scanned and showing nothing amiss although it is basic.
It's run on Shell V power nearly always.
As I understand it enrichment is achieved by drawing fumes collected in the charcoal canister opened by a valve when required, I may be wrong on this but the valve works and when powered up remotely it makes no difference. The inlet pipe to the canister the rear isn't blocked and when the canister is bypassed completely ie.connected straight to the inlet manifold it still hesitates.
I may be looking in the wrong place as I don't understand the workings of the V6 as I do the diesels but do understand the fundamentals.
There may be a simple solution to this I just need pointing in the right direction.
I think there is a fuel filter somewhere along the line I replaced 20K miles ago which I might investigate.
Back to the drawing board as they say.
Thanks.
Thanks.
