Beau
- Jan 28, 2011
Ok guys,
I think I have a bad injector... A few symptoms are the following
- Takes a bit longer than usual to start 3-4 seconds of cranking. There is no air in the fuel, and fuel is not draining back.
- Slight miss when cruising at around 75-80 and call for a little bit more power
- No smoke at all...
- Slight vibration when cruising at 70+ and call for more power (I think it's the engine missing)
When I recently put the head back in, I had 8 injectors to chose from. I should have just put back in the 4 that I knew were in good shape but long story short, they all ended up in a box mixed up. So when it came to putting the injectors in I selected what looked to be the best ones and stuck them in. Since then, I've been having these slight issues and think it's down to a injector. I've ticked off everything else possible. Anyone else have anything similar problem wise?
I'd rather not just swap one injector here and there and replace randomly, so Other than getting them checked professionally, is there anyway to isolate a bad injector/test them?
Thanks!
Thanks!
