Joakim Forøysund
- Jul 16, 2019
It finally happened! I've wanted one for years, and now this one sits outside our home, waiting for some new parts. I need to fix a few minor issues before I bring it to mandatory roadworthy test. Then I can (hopefully) get the license plates back on.
Here she is, together with our Volvo.
The missus has declared this one is hers, and I can just have the Volvo.
It doesn't show here, but the interior needs some soap.
Breather is clogged, and the seal probably needs to be replaced. There's oil everywhere. I have no clue how much is left inside there. Fresh drops showed after driving a short distance, so I took the chance to drive home.
Some rust, but it seems there's nothing major. Fluid Film will take care of this, I'm certain.
Underneath the round hole in the traverse is the only place I've found major rust. Here it has rusted through a few centimeters. I've inspected the entire frame as good as I can, and I can't find anything else alarming.
I ordered 20 kg worth of parts from Milner. All front bushings, water pump, belts and other service parts plus seal for the rear diff and new breathers. I also ordered a new radiator, just to be certain.
That's enough for now. See you lateer!
- I already fixed a couple of electric faults on the rear lights
- Wipers are working again (the link had come off), and I cleaned the interior.
- A new digital radio is in place.
- Painted the tow bar to make it look nicer and removed the spare wheel cover.
- Pressure washed the frame inside and outside. The Kärcher gutter washer works very well for the purpose:
