Peewee
- Oct 7, 2018
Hi
My money pit of an early 2006 HZJ79R is trying my patience
Short story....
Sprayed lubricant down the keyhole of the ignition barrel as the key release button was getting sticky.
Now I have to wobble my key to turn on the ignition.
I'm going to assume my ignition barrel was full of gunk, but now clean, is worn out or am I being a bit premature?
Any suggestions of what is really the problem or a link to a matching set of key barrels for the ignition and doors?
If I replace the ignition barrel is there anything else I should change while I have the steering column apart?
I did a forum search and couldn't find anything and will call Toyota in the morning.
Pete
Short story....
Pete
