- Mar 7, 2010
I am in the process of removing my injection pump to have it refurbed, it’s a 12 valve 1HDT.
all undone & moves back & forth about 5mm , the ‘mounting flange’ that holds the pulley on the front, ( the flange about 2" diameter,with the locating pin in it ) just won’t seem to budge.
it’s all as in the FSM, with the 8mm puller bolts and a screw down puller bolt in the middle and is really flipping tight on there, using an 18” breaker bar on the middle bolt to try to get it to separate and am worried about pulling the 8mm ‘holding bolts’ out of the flange, it’s that f……in tight!
have tried freeze spray on the shaft as well
has any one else had issues like this or shall I just keep on winding the middle bolt in & hope?
any suggestions / experiences welcome
ta
Andy
ta
Andy
