Looks like the gremlins may have stuck. All that exertion this weekend has resulted in a leak in the worst place. Until proven otherwise that is. It's clearly ATF and looks to be coming out of the bell housing.
Damn
Damn
YesChris said:The TC is that rounded drum thing with vanes inside
No, I'm remembering a locator that goes into the centre of the fly wheel and helps line everything up so you can get the bolts fitted to hold the TC to the fly wheel? I don't remember any tubes sticking outChris said:and a short tube sticking out of it yes?
If it's a slight weep I think you are safe for ages but if it's more of a dribble then it might let go quite soon. You've double checked it's not just a bad fit at the lower dipstick tube and then just being blown about? Clutching at straws for youChris said:Other than leaking all over my drive, is there any major 'ooh dear' with this leak. Is it simply weeping there or is there tonnes of pressure about to be unleashed whilst driving.
Hi Chris, sorry to hear of the ATF leak, do I and the engine crane need to be on standby again?Chris said:Where's Scott when you need him. At least I have been there before so I know what's what.
