2 years ago i stucked in a mud area..alone ..(dimensions 60 mtrsx 60 mtrs)so when came a rescue car it wasnt possible to catch me..also no trees around..this was a lesson for me..must be fully independent
from that moment carrying always 100 mtrs extra wire to the car plus belts 50 mtrs totally
but i start to construct my land anchor to the same dimensions and weight as a brand name..
i had only 4 dimensions weight length height breadth so i must design it to a scale in a paper
5mm steel plate everywhere
http://s815.photobucket.com/albums/zz71 ... %20anchor/
finally the construction has 16,2 kgs not because of wrong calculations but of reinforcing some points
..if there is any chance to brake somewhere the anchor (original or not ) this point will be as u ll see to the first photo(with the red arrow)..so i weld 2 small plates to the vertical steel plate and 2 tie rods make the constuction more heavily
in a while u ll see it in action
