Charlie
- Apr 9, 2010
Used National Luna 60 L Fridge Freezer for, good working order and in excellent condition £650
Description borrowed from APB website,
Dual thermostats allow settings of the dual fridge, dual freezer or a combination (where the smaller, more efficient compartment should be used as a freezer). This makes it the ideal combo unit for those looking for maximum storage capacity but still in overall efficient size. Compared to using 2 separate fridge/freezers the 60 Dual uses less space and much less battery consumption.
The National Luna 60 Lt Legacy Fridge/Freezer Dual control has full height and full wrap-around cooling plates to each compartment, unlike some other brand combo units, meaning it doesn’t rely on internal fans or removable panels to maintain proper performance.
The LH compartment is almost 25Lt and features 60mm thick wall insulation for excellent Freezer performance. The RH Compartment uses 42mm wall insulation to give an amazing 35Lt of Fridge space. However, the dual thermostats mean that both compartments could be used as a Fridge depending on your needs.
12/ 24v DC and 240v AC are all built-in and the unit will automatically select to run on mains power whenever it is available – but revert to battery power if the mains go off. Adjustable low voltage cut-out.
Two digital thermostats ensure each compartment maintains your desired temperature range without the need to adjust for hotter or colder weather.
This model has 5 plastic baskets fitted.
