------=_NextPart_001_003C_01C5295D.E8F0A6F0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Christopher,
Excellent write up and good innovation, I would never have thought to use 3
core mains wire. I thought about using fused relays rather than in line
fuses not that it makes any difference. Any baling twine to go with the
tape?
Anthony
_____
Behalf Of Christopher Bell
Sent: 15 March 2005 12:01
To: [Email address removed]
Subject: RE: [ELCO] [lights,bulbs]
Hi christopher
I had no problem replacing the inner bulbs, it only took a minute or so, it
is a bit fiddley with the batteries in the way ant the clips. My inner ones
do work and always have, there the ones that really make the difference on
the dark country roads at night. The inner connectors are different than the
H4 connectors, the inner ones have a connector just to fit the bottom of
the H1 bulb which only has one terminal at the base compared to the three at
the base of the H4.
They obviously do it differently on the later model (mine's 1996) - maybe
they added the adaptor later.
On the subject of the bulbs and the wiring. Yes its a question, what is
meant by upgrading the wiring, is it using thicker wiring or a different
type of wiring which loses less power on its way to the bulb.
Both . Toyota have put in relief relays for the headlights (in the fusebox
at the front left of the engine compartment) to relieve the current on the
dashboard switch and wiring, but they still manage to lose a lot of volts by
hook or by crook.
What I have done is:
* Use the existing sockets that attach to the bulbs to provide power
for separate relays.
* In fact you only need the H4 bulb socket on each side, as this
provides common, dipped and main.
* Thus I have two relays on each side: one for dipped beam and one for
main.
* The relays only draw a fraction of an amp each, so the existing
headlight wiring runs them easily.
* The "power" leads (+ve) to the relays have been been taken from
battery +ve terminal (RHS), and starter changeover switch (LHS)
* I have put a separate 40amp in-line fuse in each lead, and used
heavy duty cable.
* Then the +ve power goes one side of each relay, and the switched
side goes (heavy duty wiring again) to new headlight socket bases.
* -ve (heavy cable again) goes from chassis earth on each side - there
is a convenient bolt there for the purpose - to bulb socket base.
This way the current supply to the lights is as direct as possible, giving a
minimal voltage drop.
A safety note:
* Power each side separately through a separate fuse. Using a single
common fuse for everything leaves you in total darkness if it blows....
* Don't attach any wiring to the front LHS battery. This swaps to 24v
during starting.
* Be consistent with your wiring colours, ideally red or brown for
+ve, black for -ve.
I used ordinary 3 core 5amp mains cable for the "old headlight socket to
relay" wiring: using yellow/green (earth) for common, blue for dipped and
brown for main. On the heavy current side I used (separate) brown for main,
blue for dipped and black for earth.
I found that H4 headlight base units have the same dimensions as ordinary
car relays, so I scavenged a couple, ripped out their innards, soldered the
cable to their terminals, and these plugged directly into the old sockets.
Note that this (coil) side of the relays is not attached to chassis earth,
so it doesn't matter whether Toyota decided to switch +ve or -ve sides.
I took the +ve feed for the LHS assembly from the terminal on top of the
starter changeover relay simply because that is attached directly to +ve on
the RHS battery, and saved me stringing a cable across the front above the
radiator somewhere. Simply trace the heavy-duty cable back to the +ve
terminal on the RHS battery, and you have the correct terminal on the relay.
I made two units, one for each side. I bought a length of kitchen sink
drainpipe (99p for 2m), bashed it into a squarish cross-section by hammering
a piece of wood into it and heating it, and used roughly a 5" length of this
to hold the relays. I blocked off one end with silicone sealant, pushed the
relays in with the wires coming out of the other end, then wrapped liberally
with silage tape (wide masking tape) to water-proof it.
When sizing fuses and relays I allowed a factor of at least two. So the
load on main beam might be 130w + 100w = 230w each side, or about 17amps at
13.5volts, so I used 40 amp relays and fuses. In a similar vein all spade
terminals, connectors etc want to be heavy duty.
The end product is attached via those plastic ties to the cable ducts
running down each side next to the headlights. So I didn't drill any holes
or cut any Toyota wiring.
Here is a very quick & dirty wiring diagram
Hope this helps
Christopher Bell
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" xmlns
ffice
ffice" xmlns:w=3D"urn:schemas-microsoft-com
ffice:word" xmlns:st1=3D"urn:schemas-microsoft-com
ffice:smarttags" xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<!--[if !mso]>
<style>
v:* {behavior:url(#default#VML);}
o:* {behavior:url(#default#VML);}
w:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style>
<![endif]-->
<title>Message</title>
<o:SmartTagType namespaceuri=3D"urn:schemas-microsoft-com
ffice:smarttags"
name=3D"City"/>
ffice:smarttags"
name=3D"place"/>
ffice:smarttags"
name=3D"PersonName"/>
<!--[if !mso]>
<style>
st1:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-margin-top-alt:auto;
margin-right:0cm;
mso-margin-bottom-alt:auto;
margin-left:0cm;
font-size:12.0pt;
font-family:"Times New Roman";
mso-believe-normal-left:yes;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color
urple;
span.EmailStyle17
{mso-style-type
ersonal;
color:blue;
font-weight:normal;
font-style:normal;
text-decoration:none none;}
span.EmailStyle18
{mso-style-type
ersonal;
color:blue;
font-weight:normal;
font-style:normal;
span.EmailStyle19
{mso-style-type
ersonal-reply;
color:blue;
font-weight:normal;
font-style:normal;
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:338433003;
mso-list-template-ids:-1396026978;}
@list l0:level1
{mso-level-number-format:bullet;
mso-level-text:F0B7;
mso-level-tab-stop:36.0pt;
mso-level-number-position:left;
text-indent:-18.0pt;
mso-ansi-font-size:10.0pt;
font-family:Symbol;}
@list l1
{mso-list-id:736249235;
mso-list-template-ids:-1631683246;}
@list l1:level1
</style>
<![if mso 9]>
<style>
p.MsoNormal
{margin-left:1.5pt;}
</style>
<![endif]><!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body bgcolor=3Dwhite lang=3DEN-US link=3Dblue vlink=3Dpurple style=3D'margin-left:1.5pt;
margin-top:1.5pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dblue face=3D"Times New Roman"><span
style=3D'font-size:10.0pt;color:blue'>Christopher,<o
></o
></span></font></p>
style=3D'font-size:10.0pt;color:blue'>Excellent write up and good innovation, I
would never have thought to use 3 core mains wire. I thought about using
fused relays rather than in line fuses not that it makes any difference. Any
baling twine to go with the tape?<o
></o
></span></font></p>
style=3D'font-size:10.0pt;color:blue'>Anthony<o
></o
></span></font></p>
style=3D'font-size:10.0pt;color:blue'><o
> </o
></span></font></p><div>
<div class=3DMsoNormal align=3Dcenter style=3D'margin:0cm;margin-bottom:.0001pt;
text-align:center'><font size=3D3 face=3D"Times New Roman"><span style=3D'font-size:
12.0pt'>
<hr size=3D2 width=3D"100%" align=3Dcenter tabindex=3D-1>
</span></font></div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>
<font size=3D2
face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font><font
size=3D2 face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma'> [Email address removed]
<span style=3D'font-weight:bold'>On
Behalf Of </span>Christopher Bell
<span style=3D'font-weight:bold'>Sent:</span> 15 March 2005 12:01
<span style=3D'font-weight:bold'>To:</span> <st1
ersonName w:st=3D"on">[Email address removed]</st1
ersonName>
<span style=3D'font-weight:bold'>Subject:</span> RE: [ELCO] [lights,bulbs]</span></font><o
></o
></p>
</div>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span style=3D'font-size:
12.0pt'><o
> </o
></span></font></p>
<blockquote style=3D'border:none;border-left:solid blue 1.5pt;padding:0cm 0cm 0cm 4.0pt;
margin-left:3.75pt;margin-top:5.0pt;margin-right:0cm;margin-bottom:5.0pt'>
<blockquote style=3D'border:none;border-left:solid black 1.5pt;padding:0cm 0cm 0cm 4.0pt;
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'><font size=3D2
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>Hi christopher</span></font><o
></o
></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'><font size=3D3
face=3D"Times New Roman"><span style=3D'font-size:12.0pt'> <o
></o
></span></font></p>
</div>
<div>
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>I had no problem
replacing the inner bulbs, it only took a minute or so, it is a bit fiddley
with the batteries in the way ant the clips. My inner ones do work and
always have, there the ones that really make the difference on the dark country
roads at night. The inner connectors are different than the H4 connectors, the
inner ones have a connector just to fit the bottom of the H1 bulb which
only has one terminal at the base compared to the three at the base of the H4.<font
color=3Dblue><span style=3D'color:blue'> </span></font></span></font><o
></o
></p>
</div>
</blockquote>
</blockquote>
<div>
color=3Dblue face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;
color:blue'>They obviously do it differently on the later model (mine's 1996) -
maybe they added the adaptor later. </span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>On the subject of
the bulbs and the wiring. Yes its a question, what is meant by upgrading the
wiring, is it using thicker wiring or a different type of wiring which
loses less power on its way to the bulb.<font color=3Dblue><span
></o
></p>
</div>
</blockquote>
</blockquote>
<div>
color:blue'>Both . <st1:City w:st=3D"on"><st1
lace w:st=3D"on">Toyota</st1
lace></st1:City>
have put in relief relays for the headlights (in the fusebox at the front left
of the engine compartment) to relieve the current on the dashboard switch and
wiring, but they still manage to lose a lot of volts by hook or by crook.</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>What I have done is:</span></font><o
></o
></p>
</div>
<ul type=3Ddisc>
<li class=3DMsoNormal style=3D'mso-list:l1 level1 lfo1'><font size=3D2 color=3Dblue
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Use
the existing sockets that attach to the bulbs to provide power for
separate relays. </span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>In
fact you only need the H4 bulb socket on each side, as this provides
common, dipped and main.</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Thus
I have two relays on each side: one for dipped beam and one for main.</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>The
relays only draw a fraction of an amp each, so the existing headlight
wiring runs them easily.</span></font><o
></o
battery +ve terminal (RHS), and starter changeover switch (LHS)</span></font><o
></o
have put a separate 40amp in-line fuse in each lead, and used heavy duty
cable.</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Then
the +ve power goes one side of each relay, and the switched side goes
(heavy duty wiring again) to new headlight socket bases.</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>-ve
(heavy cable again) goes from chassis earth on each side - there is a
convenient bolt there for the purpose - to bulb socket base.</span></font><o
></o
[/list]
<div>
color:blue'>This way the current supply to the lights is as direct as possible,
giving a minimal voltage drop.</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>A safety note:</span></font><o
></o
></p>
</div>
<ul type=3Ddisc>
<li class=3DMsoNormal style=3D'mso-list:l0 level1 lfo2'><font size=3D2 color=3Dblue
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Power each
side separately through a separate fuse. Using a single common fuse for
everything leaves you in total darkness if it blows....</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Don't
attach any wiring to the front LHS battery. This swaps to 24v during
starting.</span></font><o
></o
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Be
consistent with your wiring colours, ideally red or brown for +ve, black
for -ve. </span></font><o
></o
[/list]
<div>
color:blue'>I used ordinary 3 core 5amp mains cable for the "old headlight
socket to relay" wiring: using yellow/green (earth) for common, blue for
dipped and brown for main. On the heavy current side I used (separate)
brown for main, blue for dipped and black for earth. </span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>I found that H4 headlight base units have the same dimensions as ordinary
sockets. Note that this (coil) side of the relays is not attached
to chassis earth, so it doesn't matter whether <st1:City w:st=3D"on"><st1
lace
lace></st1:City> decided to switch +ve or -ve sides.</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>I took the +ve feed for the LHS assembly from the terminal on top
of the starter changeover relay simply because that is attached directly
to +ve on the RHS battery, and saved me stringing a cable across the front
above the radiator somewhere. Simply trace the heavy-duty cable back to
the +ve terminal on the RHS battery, and you have the correct terminal on the
relay.</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>I made two units, one for each side. I bought a length
of kitchen sink drainpipe (99p for 2m), bashed it into a squarish cross-section
by hammering a piece of wood into it and heating it, and used roughly a
5" length of this to hold the relays. I blocked off one end with
silicone sealant, pushed the relays in with the wires coming out of the other
end, then wrapped liberally with silage tape (wide masking tape) to water-proof
it. </span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
<div>
color:blue'>When sizing fuses and relays I allowed a factor of at least
two. So the load on main beam might be 130w + 100w =3D 230w each side, or
about 17amps at 13.5volts, so I used 40 amp relays and fuses. In a
similar vein all spade terminals, connectors etc want to be heavy duty.<o
></o
></span></font></p>
</div>
<div>
color:blue'> <o
></o
></span></font></p>
</div>
</div>
<div>
color:blue'>The end product is attached via those plastic ties to the cable
ducts running down each side next to the headlights. So I didn't drill any
holes or cut any <st1:City w:st=3D"on"><st1
lace></st1:City>
wiring.</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>Here is a very quick & dirty wiring diagram</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'><img width=3D640 height=3D512 id=3D"_x0000_i1025"
src=3D"cid:
[email protected]" align=3Dbaseline border=3D0></span></font><o
></o
></p>
</div>
<div>
color:blue'>Hope this helps</span></font><o
></o
></p>
</div>
<div>
></o
></span></font></p>
</div>
<div>
color:blue'>Christopher Bell</span></font><o
></o
></p>
</div>
</div>
</body>
</html>
------=_NextPart_001_003C_01C5295D.E8F0A6F0--
