LJ70 Glow Plug Wiring
Can anyone help with details of the Glow Plug wiring. My LJ70 does not like starting in this cold weather. I have removed and checked the glowplugs, they are OK. The warning light only stays on for a short time. I found the timer relay today and that is working correctly but it is not directly connected to the plugs. Having removed all the relays under the bonnet that I can find I still can't find the other one in the circuit? Next step is to remove the outerclasing of the wiring loom to trace the wires but I would rather not. The manual I have is very vague about this area so not alot of use.
Dave
LJ70 1989 Colway AT's and 12months MOT
The glow plug relay should be connected to the plugs, there is a cable
connection where it connects to the timer wire but they go to the
plugs together. There is another relay on European models for after
glow, this is connected through a resister to the plugs. Does the
engine not start, or start and then falter?
Regards, Clive.
Sorry David, just got back to this. I can't help there as I have not
had a problem with the 70. Both the books I have for it are vague.
Regards, Clive.
