LJ70 or BJ70 axle upgrade
ChrisvW
zimbabwe
Hi Guys, just wondering, how hard would it be to fit axles from a leaf sprung troopie to a coil sprung Bundera? I'm interested in the disk brakes all round, stronger axles and free floating setup in the rear. Anyone done similar? Does anything need to be done with the transfer case or can it bolt straight up?
Transfer all the monuts from coil to leaf.
Front can not be done unless 1990 and newer with 80 series center bolted in ... no advantage over your front now.
Tcase will work fine.
Hey Crushers, thanks for replying. Will they bolt straight in to the BJ70 which has leaf springs at the moment? Considering using the LJ70 as a body donor...
