- Sep 11, 2013
Yep picture would be good, so 10mm all together, did you stick the stainless steel to the ply???
I did this before Xmas on my J10 Project vehicle.
It came with 1,5mm alloy.
Alloy is NOT ideal if You intend to cook on it.
I opted for a 9mm plywood. I removed the original plugs & inserted pop-nuts instead. Then transpered the bolt pattern to the 9mm marine grade ply & laid down the 1mm stainless steel food grade (316) ontop.
EVERSO slight snag between the SS top & the smal flap between the body & the lower tail gate. Nothing that bothers me tbh.
Tell me if You need pics
