Hi All.
I have a problem with my 1998 LC 90 series that has started happening recently.
When I turn on the main light switch and I have the stalk in the dipped beam, the dipped beams lights work fine. When I move the stalk to the high beam position to activate the high beams, the blue light on the dash comes on but the main beams don't come on and the dipped beams go out. When I reactivate the stalk for dipped beams, the blue light on the dash goes out and the dipped beams come on.
Now here is where it gets strange. When the main light switch is switched off and the stalk is in the dipped beam position, the dipped beams only (no tail or side / parking lights) are on. When I put the stalk into the high beam position, the blue light on the dash comes on but the full beams do not come on.
I have tried changing the stalk but that did not work and I have also tried swapping the relay with the relay for the power outlet but that doesn't make any difference.
Has anyone got any ideas, solutions to my problems........
E
E
