I've got the Maxxis Creepy Crawlies 37's, works fine for me, a bit on the noisy side on the road though.
The treps are some of the best comp tyres out there, it's all down to what you are using it for.
I looked at Treps a few years ago. Very good tyres but they are soft so they might not last too long if you're doing many road miles. Also directional so can't be swapped around. Primarily a competition tyre I believe. I'd imagine they're good off-road. Not a cheap tyre either - you could probably buy 6 KM2s for the price of 4 Treps.
the 80's mainly used for 'mad sundays' so the wear rate isn't important
nor is the price when you can't make a climb in front of all the onlookers
i smashed my front bumper on the first attempt
and hit a tree on the second,then reversed out of control into another 4x4!
i need more grip to match my ambitions and better than my skill
Use a sealant when you mount the tyres or put tubes in them, I had beadlocks and never had a problem to be honest but depends on how good the beadlocks are fitted to wheels
