Missing bush and bump stops etc?
cbv8
Hi All,
After dropping the fuel tank to repair rotted fuel lines i have discovered a bush missing and also the bump stops as seen in the pics can i get these bushes and is this the norm for them to be missing on these trucks and would this explain the big thud i get when going over speed bumps? also what is the black plastic thing in the middle of the subframe?
I'd guess the missing bump stops ( which is a common occurrence) might be a Milner or Roughtrax part. Otherwise Toyota.
The bush thing on the subframe above the chassis is how it should be.
There's one on the offside the nearside one is missing i cannot see this bush advertised on the Milner or Roughtrax site unless im missing something :?
