having filled up the tailgate, i still needed a bit more space to store my crap out of the main boot are and out of sight. So, a while ago i started making a storage box to set into the floor of the boot. An icelandic chap had done so on ih8mud, so i decided to make one as well. my spare lives on a spare carrier so all the space under the floor was wasted.
Construction is an angle frame with galvanised sheet cladding. I wanted to use stainless to do it, but it was too expensive, so mild steel and galvo it is. Making it took much longer than i expected, but its now just about done and i'm pretty pleased with the results as it meets all of the criteria i noted, namely holding a jerry can upright and not hanging below the tow bar brackets where it could get bashed. Need to make lids and a floor now, but that will have to wait until i can get to the timber merchants. i have found someone reasonably close by breaking an 80 so i should be able to carpet the lids with the same carpet as the rest of the car. I should also be be able to get some replacement tailgate carpet. as you can see, the previous owner did not take very good care of it and the carpet has some bald spots.
here's some pics, more to follow once i get some materials.
