cruiser 3.0 70
- Nov 9, 2012
I put this led lamp on the weekend and wired it into the rear wiper loom which I removed because the motor was seized so took feck all time at all happy with the way it worked out,since I've got my kzj I've repaired a small rust hole drained the cooling system an refilled with coolant,fitted two new front shocks,and brake discs and pads,rear shoes,new clutch master and slave cylinder seals,a CD player,kingpin bearings,fitted front spot lights welded up the leaky exhaust,fitted new bulb in the dash for the door open light,got the heater working,drained all oils and replaced,fitted new front wiper linkage,Put a set 225 75 16 of bfg km2s,new window winder handle,new ball hitch and 10.9 bolts,2nd rear tail light,I'm sure there is other stuff I 4got and there's lots more to do.all my future work I'll try and put up pictures And 1 day I might get as many views as Ben but I doubt it
