Well, All in all changing the seal was pretty straight forward. Though if your going to do it I'd suggest you do the bearing while your in there...
I struggled with a few things and would suggest that you make sure you have a torque wrench that goes up to 245 N.M. Mine, as I found out
, only goes up to 210 N.M...
When I eventually managed to get the nut up to 210 N.M I could only get about another 1/8th of a turn on the nut. I then checked the preload as per the FSM which should be between 0.7 - 1.0 N.m with a used bearing. Mine is sitting around 20N.m...
If your preload is too high the spacer should really be changed out. To get to the spacer you need to remove the bearing. May as well replace it.
Lastly I have noticed diff oil seeping out from the diff lock actuator...WTF?
The new seal seems to be working but why would it be coming out of the actuator?! Could I have overfilled it???
Other than that it was pretty straight forward really...
One last tip tip, make sure you chock your wheels. Park doesn't really work when you remove your rear propshaft and that's no good when your drive is at a slight angle...
If you need a copy of the FSM drop me a PM with your email and i can forward the relevant section to you.
I'm starting to think I should change my signature to: "Learing things the hard way, so you don't have to...
