Allchin
- Nov 16, 2010
I thought I would start a new thread as the subject has changed.
I had a leaking ASCD and has being slowly getting worse. The last 3 months it has been left in the drive. Recently I removed the ASCD to check to see how bad it is. It probably needs changing but I wanted to get the engine going so I can put it in the garage to start work on it. Then I can remove the pump and injectors to have a specialist set them up again and also change the ASCD, while I work on wheels and transmission. The problem is that it still does not start after I have replaced the ASCD. The leak has stopped. I have had the engine start but only around a smooth slow tick-over and while I keep pressing the primer! As soon as I stop the engine stops. It will not rev, just a slow smooth tick-over, then stops around 30 secs later. any clues to what's happening?
Stephen
Stephen
