- Nov 19, 2010
No work today so I thought I'd change the awning on the 100 series from the Foxwing to my recently acquired OstrichWing.
What a job, strip it down so that the brackets can be moved along to suit the existing brackets, put it back on to get its location right. Fabricobble a bracket to give it rigidity ( when all you have is a bit of square tube and a strip of S/H plate) and reinforce the existing brackets . Get it all in the right place. Take the bugger off again to build it up, then put it back on whilst having to have it open to get to the rear bolts.
The note to myself and others is, don't try to do this on your own, I had a bit of help from a fork lift but it was still a time consuming exercise
Remember, a dull pic a good welder makes
