OBD in 2003 Troopy
Heath
australia
Hi all, first post - be kind. Trying to find out if the 2003 troopcarrier with 1HZ has a OBD port (or similar).
Done a fair bit of searching around unable to find the answer. From what i can tell it doesnt have one, but thought i better ask just in case.
There's nothing wrong with the the troopy, would like to know where it is if anything goes wrong.
(Wiring not done by me)
If you don't get an answer here, I suggest checking the Lcool.org forums (OZ), as that's where most of the troopys are located.
On those that have OBD (and that would be M-OBD, not OBD-II); there's a plug on top of the RHS fender (your driver's side) with a black lid marked Diagnostic, and an OBD plug above the driver's legs somewhere.
And welcome to the forum. A better intro, with pics, will be appreciated.
If it's diesel with a mechanical injector pump then no as its got nothing to read
Cheers guys, had a good look and cant find anything, i guess there is nothing there. Thanks for your help!
Better intro photo as requested. Will do a write up of it soon.
