Offering 2.4 Manual injection engine
Bund
great_britain
Bad bits - Likely head gasket gone & mileage around 190k with no history prior to the big service i had done as soon as i bought it.
Good bits - 600 miles ago lots of the oils seals were replaced as an oil leak was found coming from behind the cambelt casing which resulted in removal of the radiator and all outer cambelt casings and leak found coming from lower rear cover.
Answer - new seals, gasket rocker, timing case, strainer gasket, gasket block and a new cambelt & water pump.
Invoice was about £1000(most was labour) not including the cambelt kit and water pump.
Can be collected from Market Drayton.
Open to offers.
Afternoon,
I’ll get some photos once it’s out of the truck.
Parts in particular?
